Hi,
This is pretty annoying. Every commercial DVD i rip to .avi, i get audio desync on the 2nd part vob with VDubMod (or every .vob proceeding the 1st part).
I'd just like to know why this is!?
i.e. audio is fine on 01_1, but 01_2 is out-of-sync.
I don't know whether its best to combine the 2 vobs that compose 1 episode and then rip, or rip them seperately, but apply a audio skew to the 2nd to bring it back in line, then combine the rips.
Pls help and say whether this happens to you with VDubMod on DVD Conversion!!!
P.S. I ripped and then applied a skew afterwards, but i have audio of missing scenes and no audio of what is displayed![]()
"Youth is wasted on the young."
Rip the disc as one big lump of video. Use DVDDecrypter - File Splitting NONE.
I also have a habit of converting the audio from AC3 to .wav if I am working extensively in VDub.....it just makes thing easier...at least for me. -
No, because I do it right. There's always a delay on every VOB after the first. The best way is to decrypt using DVD Decrypter in IFO mode (or one of the newer decrypters in Movie Mode), and that way you'll get only the movie you want, and nothing else, like extras, that might be in that VTS. Then I'll make a D2V project file after opening all of the VOBs at once in DGIndex. In the process, DGIndex will also demux the audio into one file. And then I'll use the D2V file it makes in an AviSynth script to frameserve into the encoder, VDubMod in this case. This is all thoroughly explained in the documentation that accompanies the DGMPGDec package.Pls help and say whether this happens to you with VDubMod on DVD Conversion!!!
And if you don't want to try your luck doing it the AviSynth way, then maybe let AutoGK do the whole job for you. No one encodes the VOBs separately. -
YES! I have file splitting on DVD Decrypter "By File" [Tools -> Settings -> File Mode]
I will try "None", and get back to u.
x.264 conversion takes a few hours, especially if I'm now doing it all-in-1.
Cheers fellas
"Youth is wasted on the young." -
SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEETTT!!!!!!!!!!
I had to drop back and say a BIG thank-you to hech54 for suggesting i use File Splitting none with DVD Decrypter!
My audio desync problems with DVD-rips are gone for good
BIG SMILEY!!!"Youth is wasted on the young."
"fixed" AVI has audio sync and video blocking problems
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 05:00 -
Burned a 2prt avi to dvd Loss of audio on 2nd part of the movie.
By Ryanmhindman in forum AudioReplies: 2Last Post: 22nd Sep 2009, 14:43 -
Help Converting XVid AVI to x264 with VDubMOD or other?
By incrediblej in forum Video ConversionReplies: 5Last Post: 1st Jan 2008, 14:13 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
VDubMod Audio Sync Problems, Help!
By blueprint in forum Newbie / General discussionsReplies: 21Last Post: 20th May 2007, 23:18
